AJ's Disco 2 VW Diesel Swap
TLDR so far:
Bought a 2003 Disco 2 with a blown head gasket. Did my own head gasket job, engine immediately overheated. Unclear to me why (I check the deck and heads with a straight edge). Tore down the block and sent it to a machine shop. 3 months of machine shop jail later, I started working on the engine swap on the side. Now the engine swap has gone from Plan B to Plan A. The PLAN:
Details on trans:
Parts: front to back
To Dos:
This could be interesting. :popcorn:
March 4th update:
https://cimg2.ibsrv.net/gimg/landrov...aed437d4bb.jpg |
I am watching this with so much enthusiasm!
Do you have any more photos? |
I've got the week off work so I plan on getting a good bit of progress. Todays update includes test fitting the engine for the first time. everything fits with plenty of space to spare in front and the back.
https://cimg0.ibsrv.net/gimg/landrov...c6c1302a21.jpg I also tacked together an engine mount of the driver side. Plenty of clearance for the factory oil filter housing and oil cooler. Still missing the TDI to LS T56 adapter so I am only eye-balling and tacking things together for now. The TD conversion adapter is listed at 2in thick so I added 2in of wood between the engine and trans. The TD conversions mount will allow me to clock the engine so until I have the right clocking position I will leave the mounts only tacked together. https://cimg1.ibsrv.net/gimg/landrov...4f10a8176a.jpg https://cimg0.ibsrv.net/gimg/landrov...3b76b8a135.jpg Also peep the axle clearance. Don't suspect I will have an issues there. https://cimg2.ibsrv.net/gimg/landrov...409dd2d52f.jpg Unfortunate side note: The disco 2 power steering pump directly bolts to the factory VW accessory drive bracket. But, this bracket does not fit in the car because it hits the steering box. This would have been a great solution if not for the steering box getting in the way. Still considering moving the engine to the passenger side to make room. https://cimg7.ibsrv.net/gimg/landrov...cea808aeea.jpg Next to do items:
ROW modules from a diesel with a stick could solve the issue possibly and maintain the other vehicle functions
FINALLY. The adapter has arrived. Engine is in and mated to the transmission. With this I was able to finish the driver side engine mount. Passenger side is tacked together for now until I get the new turbo installed. Decided to go with a larger, top mount turbo due to the turbo, starter and passenger engine mount all wanted to exist in the same area.
I also removed the pedal box and added a clutch pedal. The pedal is hand made from scrap I had laying around. Still waiting on the clutch master cylinder before I drill the holes for it. I also welded on a mount for the VW diesel accelerator pedal. The plan is to reuse the cable throttle hole for all the VW related powertrain wiring. Driver side engine mount: https://cimg8.ibsrv.net/gimg/landrov...7fb6e51b07.jpg Overview of the engine in the vehicle. Looks at home. Wiring is a spaghetti mess right now but it'll come around soon enough. https://cimg9.ibsrv.net/gimg/landrov...7312122eb8.jpg Picture of the pedal box. VW gas pedal, scrap metal clutch pedal. I reused the spring from the rover gas pedal on the clutch. Looks pretty OEM actually. Will look better with paint. But that will have to wait until I get the right clutch cylinder installed. https://cimg1.ibsrv.net/gimg/landrov...c0840ec8c3.jpg Progress has been slow but we'll get there. Main items still to do:
ArmyRover, While I think the ROW diesel modules might work great, I would probably also need all the wiring from those vehicles. To me the main things I need are Tach, coolant temp and oil pressure indicator. With that I would just need 3 rover sensors adapted to the VW. 2/3 are already done. The only one I still have to somehow attach is the crank sensor. Still working on that. I'm also hoping that this is enough to make the other modules happy enough to not flash ABS lights on the dash. We'[ll see though. |
In my ifs 4 runner I've been daily driving on a stock 2005 Passat TDI power steering pump on @ 32 inch by 11.5 inch wide tires for 2 years and about 60,000 miles with no issues. A few jeep guys have gone with electric power steering pumps, I think Volvo and maybe Prius use them but seems overly complicated to keep adding more electronics.
Purchased bulk roll of power steering hose and some reusable fittings to adapt my VW pump to the yota ifs steering box. My AC isn't the most efficient as the VW is an r134 variable compressor on an expansion valve run r12 Toyota system. I'd imagine running the VW compressor on the disco which I believe uses oriface tubes would yield much more efficiency. My yota didn't come with a functional tach so I grafted the 2005 Passat cluster to the dash under the factory cluster outer shield. Used some abs plastic to fill in the sides. You can keep the factory disco 2 fuel pump but you need to add both a pressure restrictor to keep the fuel pump alive and tee for a return line. The pd pump doesn't want more than 15 psi even wot. My BHW is very happy on a max 15 psi old 6.2 ac Delco Chevy diesel fuel pump if you want to delete the disco pump and install an external. Very quiet |
Originally Posted by PickleRick
(Post 931977)
Purchased bulk roll of power steering hose and some reusable fittings to adapt my VW pump to the yota ifs steering box. My AC isn't the most efficient as the VW is an r134 variable compressor on an expansion valve run r12 Toyota system. I'd imagine running the VW compressor on the disco which I believe uses oriface tubes would yield much more efficiency. My yota didn't come with a functional tach so I grafted the 2005 Passat cluster to the dash under the factory cluster outer shield. Used some abs plastic to fill in the sides. You can keep the factory disco 2 fuel pump but you need to add both a pressure restrictor to keep the fuel pump alive and tee for a return line. The pd pump doesn't want more than 15 psi even wot. My BHW is very happy on a max 15 psi old 6.2 ac Delco Chevy diesel fuel pump if you want to delete the disco pump and install an external. Very quiet Ended up cutting the accessory bracket down and going with the electric power steering pump. Mounted it in the old airbox location. Didn't even have to modify the lines. Thought I could get away with running it in default mode but it's but a little to hard at a stand still. Will be hooking up the CAN connections next to fine tune the assist based on vehicle speed. For fuel pump I think I might still need to rework it slightly. I dissected the Land Rover sending unit and removed the pressure regulator and added a return. This brought the pressure down to a dead steady 20PSI. Sounds like that might still be too high. And I'm not sure how much the fuel pump is loving that pumping rate. Might invest in an external pump/filter combo (FAST/AIRDOG or something similar) I've driven the trucks few times now around the yard. Gearing is really tall but i also can't tell if the engine is in limp mode due to all the EGR components being gone. Will be working on this once the base engine components and wiring have been truely nailed down. My biggest accomplishment recently has been getting all the dash lights to turn off (this is required for me to be able to register it here in Ontario). I ended up using an Arduino to simulate the 60-2 crank signal of the original engine The Arduino reads engine RPM from VW CAN, uses that to set the PWM rate on one of its outputs, that output is then attached to the crank input for the ECM. Doing this I was able to get TACH on the cluster. By plumbing in the land rover coolant temp, oil pressure and charge light, I got all the engine related dash lights to be happy (Aside from the MIL). By dissecting the transmission I was able to get the M and S lights to turn off by plugging in the valve body and speed sensor (somehow this speed sensor doesn't need to be given any input?? It doesn't get mad when SLABS and TCM speeds are different. Seems really odd but I'm not complaining). Anyways. Next projects are the low temp air to water cooling loop, wiring wrap up and learning how to tune this engine. I refuse to pay 700$ for a "STAGE" tune so I'm slowly learning the ins and outs of this TDI ECM to do my own tuning. More pictures to follow once I get the chance to pull them from my work phone. |
| All times are GMT -5. The time now is 04:11 AM. |
