Discovery 2 LS Conversion
#811
I personally rebuilt my 04, 122k mile 4.6, cutting no corners. Then the block cracked when cranking, 3 cylinders had coolant seeping between the cylinder sleeves and block(the block that pressure tested good).
I have since gotten a "good" 4.0 block, and managed to get the bearings, crank, cam, new freeze plugs and timing chain on.
I haven't had the time to finish assembling it(even though I have all the parts, to the tune of $3k+).
In the meantime, my rear rusty frame has vaporized, meaning it needs a back half swap, new frame, or another truck to go in before it'll pass state inspection...killing most any motivation for me to work on it any further.
I wish it would just go away, lol.
What's my point? Be careful throwing good money down the rabbit hole on these engines.
#812
I agree, but I'm kind of over the whole D2 engine thing.
#813
the water is from when I took the heads out and had the engine out in the open since I took it out with the valve covers unscrewed
#814
#815
**** land rover ... this very new is a truck ... it hurts to let it lose it would be ideal to put the motor and transmission of the land cruiser fj80 🤩 but it is too much money this type of adaptations I hope it fits me well and I am very lucky. if I should take the crank and all accessories to the store
Sixpack577 (07-08-2020)
#816
If it's somehow helpful........
I have my complete 4.6 Engine still carefully dismantled and put into storage containers. The block cracked but everything else is complete and ran perfect and all the bearing surfaces and cylinder walls still have the brand new machine marks and crosshatching. So sad the block cracked on an otherwise perfect engine.
My motor only had 78k miles on it if I recall correctly so, that's about as good as one would find used. I'd be willing to part with it on the cheap. I stamped all piston/rods/bearings etc. with letters and numbers matching the crank and such so it could be put back together as it came. I intend to sell off the pieces anyway. Maybe this is helpful to someone who has a good block or would knock the sleeve out of this one and weld the block which would make it a great motor since the 03/04 have the interlocking sleeves that won't slip ever.
-Greg
-Greg
#817
-Greg
-Greg
#818
-Greg
-Greg
#819
The rods/pistons and bearings are together as a set and I have their original locations in the block stamped. So, it could be put back the way it came out of the engine originally.
#820
-Greg
-Greg
I had my 04, 4.6 bare block beside my 4.0 bare block(which I disassembled)...and they are identical, inside and out other than exterior casting numbers.
Both have the inner ridges cast into the block below the sleeves.
Toms (07-08-2020)
