Stuck in first gear ¯\_(ツ)_/¯
Ok hive mind, I need your help!
no flashing m&s lights no amigos “sport” mode “works” shifter and dash show actual gear selection in high range I only get first and reverse However! Low range manual mode I can shift through gears. any ideas on what I should be looking for? I don’t have a nanocom, is this something that a reset or code clear on that would resolve? Appreciate any help! |
Been going over the connections on the ACE box, seems like I might have flip flopped a few of the throttle position wires going into the ACE box.
Originally Posted by Jensen Vermont Stenberg
(Post 914493)
Replying here for closure. TPS was wired in wrong. So apparently if you have TPS issues the rover will not shift out of first gear.
| All times are GMT -5. The time now is 05:04 AM. |
