Voltage Regulator_Help
Old 07-15-2017, 02:58 PM
1811SAR's Avatar
Default Voltage Regulator_Help
2004 DiscoII battery died so we had Auto Zone test the alternator. It tested badly for the voltage regulator. My son and I pulled the alternator to get to the voltage regulator under the rear cover.
BOSCH #1 197 311 549
EL 14V
Made in India
883
What is the best way forward here? We can't find anyone who has the part. Is there another manufacturer or number that will work?
Attempting to save my 16 year old from an new alternator purchase.
Cheers,
G
Old 07-15-2017, 03:15 PM
1811SAR's Avatar
Default Voltage Regulator_Search Results Update
Found another BOSCH with a part number that is close:
1 197 311 213
EL 14V
Made in GB
381
Found a HUCO
13 0560
EL 14V
Made in Germany
Will either of these do the job?
Old 07-27-2017, 05:47 AM
1811SAR's Avatar
Angry No Change
Replaced the VR and got the idiot light "battery" so I gave up and took it to the local shop for an assessment.
$159.00 later, they are sugggesting a new alternator. They are being told that only one OEM exists out there for replacement and it will cost ~$650.00. I asked them at that price was it a 150 amp? The service writer couldn't answer that question...?
I told them to button it back up and I'd make arrangements for towing it home.
I got some feedback earlier about a 150 amp alternator one of you folks have upgraded to so I think that will be my best way forward... Thoughts?
Cheers mates,
Griff sends
Old 07-27-2017, 06:20 AM
mollusc's Avatar
This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself.
1811SAR (08-03-2017)
Old 07-27-2017, 07:24 AM
Received 1,465 Likes on 1,196 Posts
Fixed moved to the right forum.
Range Rover p38 alternators had a 150 amp option. Should bolt up not sure about the wiring.
The guys at lucky8 should be able to give you a much better price thsn 650
Old 07-27-2017, 08:27 AM
mollusc's Avatar
There are also new D2 alternators available from various sellers on eBay in the $150 range. 150A is higher output than the original D2 one, and it isn't essential to have that unless you run a lot of accessories.
Old 07-27-2017, 09:11 AM
Best4x4's Avatar
Received 2,238 Likes on 1,661 Posts
I've bought two from "Parts Player" off of Ebay and they've been very reliable Alternators. They looked just as nice of quality as the OEM unit vs the Auto Zone units which you can tell were rebuilt on the cheap side for double the price of the Ebay unit. Last one I bought was 134.00 for a 150AMP unit.
Old 07-27-2017, 10:15 PM
number9's Avatar
Checkout last page of this thread.
https://landroverforums.com/forum/di...y-51103/page3/
Remember when you asked before?
vjm530
07-07-2008 08:19 PM
AUSlro
06-16-2008 04:10 AM
ajh
09-30-2007 08:16 AM
BlueDisco
Audio/Visual Electronics
08-21-2006 11:44 PM
alpinab7
08-17-2006 09:54 AM
Quick Reply: Voltage Regulator_Help
