Freelander Talk about the Land Rover Freelander within.
2003 Freelander engine repair
Old Jun 30, 2011 | 09:22 AM
Rotarubrac's Avatar
3rd Gear
Question 2003 Freelander engine repair
Hi everyone ! I checked out your forum and this is an awsome site for Rover enthusiasts. Very glad I joined up and hope to make some friends here. Now, down to business...
I currently, and unfortunately own a slightly broken 2003 Freelander with a 2.5 litre V-6 gas motor.
I am removing the oil pan to install new rod bearing inserts. I hope I caught it in time before the crank was trashed. Can anyone tell me if there are bolts ect. in-between the engine and transmission? If so, then I gotta pull the engine to get the pan off...grrr
Fred S. Ashburn Va.
Retired European Auto Tech
2003 Freelander 4 whl Auto V-6 gas
Last edited by Rotarubrac; Jun 30, 2011 at 06:06 PM. Reason: Lack of proper intro and info. My bad.
Old Jul 8, 2011 | 12:02 AM
rtonder's Avatar
Download a copy of the RAVE manual which will give you detailed information on motor disassembly. You can find a link in the Disco section.
Old Oct 11, 2012 | 12:08 AM
glamor's Avatar
6th Gear
We also find that most classic car owners don't understand ignition points, and are too intimidated to service them on their own. The truth is that points were a very simple solution to the complex problem of telling your engine when to send a spark to each spark plug.
TennesseeRover
Mar 19, 2014 08:16 AM
zee
Jun 20, 2012 07:50 PM
finman
Mar 31, 2011 09:44 AM
team_lunatics
Freelander
Sep 24, 2010 12:08 PM
