-   Freelander (https://landroverforums.com/forum/freelander-17/)
-   -   Front left cv axle, What kind of oil (https://landroverforums.com/forum/freelander-17/front-left-cv-axle-what-kind-oil-39268/)
khess44 Mar 19, 2011 08:23 PM
I replaced the front left cv axle which goes into the which inputs into the automatic gearbox, but when I took the old one out black oil came out(gear oil i think). The other shaft plugs into the ird so I know where to put that oil but im not sure what kind of oil the left side uses unless it uses ird through the primary ird shaft. Somebody please clarify this. I cant find an anwer anywhere:confused:
khess44 Mar 20, 2011 11:49 PM
Im sorry I was talkng about 02 freelander se
Robin Wirsing Dec 2, 2019 04:30 PM
Quote:
Did you find the answer, and where do you put the new oil in, please let me know
Lzmdzsem Dec 3, 2019 08:56 AM
It’s generally better to make your own thread instead of necroing a 7 year old one.
That said, afaik the fluid that comes out when you pull the CV axles is transmission fluid.
Bodgit and Leggit Garage on YouTube has a pretty good video about changing CV axles on a Freelander. Their Freelander is a diesel model, but I don’t think they’re that different.
