Hi. Looking for some help. Freelander is losing power steering fluid
Please can anyone help, freelander is losing power steering fluid but can't find where is is going and not leaking on floor, the garage can't seem to find where it is going or leaking from. Any advice much appreciated.
take the big plastic cover off the engine....you should be able to see the leak better......it's likely that it's leaking on the engine or running down it and burning off before it hits the floor...my daughters leaks more so when it's hot outside, and not at all when it's cold
Thank you I will try that.
