Land Rover Freelander 2003 lose power
Hi, i got a Land Rover Freelander V6 2.5L 2003...i got a problem that begins this winter, when its really cold outside and i start the truck, the truck begin to be noisy and i lose power, i can't go up to 60km/h...i have to start the car 30min to 1 hours outside until de Temperature gauge is at the middle, after i put the car off and i restart the car and now no more noise and the truck runs "ok"....i change the fuel pump and no result, if somedy knows something about this problem let me know
Tanks you Danny |
I did hear cold weather can affect engine performance. Hm, try to check if spark plugs are still ok? If that's not the problem, try checking the wire leading to the fuel cut off switch. If the connection's bad, it could be causing your truck to lose power while driving.
