propshaft
hey guys i have a question, if you remove the prop shaft will the ird unit n vcu creat problems ...cause i hear that the vcu unit's liquid thickens and causes the ird unit to fail and then give problems to your diff ...i just want to knw if we remove the prop shaft and turn it in to 2wd can i prevent the above problems from occurring?
thank you for your help |
sure, you can drive it without the driveshaft with no problems.
Really?
| All times are GMT -5. The time now is 10:14 AM. |
