Freelander Talk about the Land Rover Freelander within.
Torque specs on idler/tensioner pulleys
Old 02-21-2015, 01:30 PM
mountainrovernc's Avatar
Default Torque specs on idler/tensioner pulleys
Does anyone know where I can find the torque specs on the timing belt idler and tensioner pulley bolts? Can't find anything in the RAVE manual - only the specs on the two mounting bolts on the tensioner unit itself - nothing on the pulley bolts. You would think there would be torque specs on them as they are so critical - the manual has specs for just about every bolt on this vehicle.
Old 02-21-2019, 07:42 AM
DISCOFETA's Avatar
I see this was never answered... I will be doing my pulleys soon. Where can I find this information?
Old 02-22-2019, 05:49 AM
Lzmdzsem's Avatar
This should have what you need (assuming you're working on a Freelander 1 KV6)
Old 04-02-2019, 06:08 AM
DISCOFETA's Avatar
When changing out the idler pulleys and tensioner assembly, do you need to put loctite blue on the bolts?
Old 04-03-2019, 01:13 AM
Lzmdzsem's Avatar
I did on mine and the Haynes manual (the manual for the 99-06 Rover 75 covers the KV6 engine) recommends it.
DakotaTravler
10-17-2018 11:28 AM
girouardrover
03-07-2012 08:36 PM
ChanchoVerde
03-22-2010 10:31 AM
mac25dm
01-20-2008 06:47 PM
Panama Jack
12-08-2007 09:01 AM
Quick Reply: Torque specs on idler/tensioner pulleys
