-   Freelander (https://landroverforums.com/forum/freelander-17/)
-   -   Torque specs on idler/tensioner pulleys (https://landroverforums.com/forum/freelander-17/torque-specs-idler-tensioner-pulleys-72138/)
mountainrovernc 02-21-2015 01:30 PM
Does anyone know where I can find the torque specs on the timing belt idler and tensioner pulley bolts? Can't find anything in the RAVE manual - only the specs on the two mounting bolts on the tensioner unit itself - nothing on the pulley bolts. You would think there would be torque specs on them as they are so critical - the manual has specs for just about every bolt on this vehicle.
Alexander George 02-21-2019 07:42 AM
I see this was never answered... I will be doing my pulleys soon. Where can I find this information?
Lzmdzsem 02-22-2019 05:49 AM
This should have what you need (assuming you're working on a Freelander 1 KV6)
Alexander George 04-02-2019 06:08 AM
When changing out the idler pulleys and tensioner assembly, do you need to put loctite blue on the bolts?
Lzmdzsem 04-03-2019 01:13 AM
I did on mine and the Haynes manual (the manual for the 99-06 Rover 75 covers the KV6 engine) recommends it.
© 2019 MH Sub I, LLC dba Internet Brands
