1995 RRC Beeps when engine running
1995 RR County Classic beeps in key position 2 and when engine is running. Same beep that you get for "don't forget to take your key out dummy" except that this beeping is in key position 2 and when engine running. Checked all door and hood barrel switches. What is she trying to tell me? Also can not shift to 4WD low.
This turned out to be cured by replacing the MFU fuse in the in dash fuse panel. I know I checked that at least 3 times... Now the internal light is staying on.
