2007 RR Sport Bluetooth/PTI help
I have tried to search this topic, no luck. My boss just got a '07 Sport and her Bluetooth phone works fine (Verizon Ravr v3), but is there a way to disconnect the phone from the car while on a call?
Say you are in the car with some passengers, a call comes in that is private. Can you stay on the call and use your phone handset vs the handsfree system? Thank you. |
RE: 2007 RR Sport Bluetooth/PTI help
The only way to go private on the phone is to turn off the blue tooth in your Razor.[&o]
This is a phone specific question. I use the Motorola Q with my 2006 RRS. With this phone during a call the right hot key allows me to access the menu. The first function on the menu drop down is to "turn off hands free". This will disconnect bluetooth and allow you to conduct a private call. As I mentioned, this advice is phone specific but if your boss is using a Motorola Razr then it may work. GL
LD |
