95 RRC starting to sound like air-cooled VW!
Having (hopefully and finally) found the cause of the stalling issue, I have another one, the truck is starting to sound like a air-cooled vw - as if there was a hole in the exhaust or headers, loud and throaty.
I've checked everywhere and I don't see any gaps or holes in the exhaust.
It might be coincidence but it also seems like I'm not getting as much power either.
Am I missing something obvious?
Thanks
Thanks
Cats
Anything I should aware of when replacing in terms of OEM vs. aftermarket, etc?
I'd prefer to remove the cats from the equasion entirely but I live in a state where that is easy to get away with... no testing.
I hear good things about the borla and magnaflo stuff... honestly I am not a "brand" expert or anything so whatever is good for the price. Just make certain you have all your tune up stuff in order. Meaning, make sure you don't have any current issues causing your air: fuel mix to be overly rich. Rich running and any good amounts of raw fuel like excessive engine cranking with no spark) running through the cats will degrade the catalyst materials and then you will have wasted some hard earned $$$.
Hello
Have you checked the exhaust manifold gaskets? I had the rear one go, just a pin hole, but it made the engine sound as thought the tappits were coming out.
If someone hadn't said, put your hand round the back of the engine and see if the exhaust is leaking where the manifold is bolted on, I wouldn't have found it. I was all set to pull the head off and do the cam, followers etc.
NKG
NKG
I think you're right.
Hello
NKG
NKG
Thanks for the suggestion.
Roverrocks
01-01-2014 11:45 PM
Lincoln Tarantino
05-02-2012 11:20 AM
Paul Grant
36
03-14-2012 07:59 PM
rangeroverhse
01-05-2010 08:44 PM
luxury1
05-04-2009 12:26 AM
