98 RR HSE - Mirror and Keyless Entry Help
So first off - the glass from one of my wing mirrors has come loose. I've gone to LR and picked up the small plastic trim ring that is broken and removed the old one. I can attach it to the mirror ... OR ... I can attach it to the motor - but I can't for the life of me figure out how to do both at the same time ... HELP?
Secondly - I've got the factory key - but when I press unlock - every door EXCEPT the drivers unlocks... It works fine when I use the key - just not when I use the remote - thoughts?
Also my Climate Control has got the book with an exclamation point - any idea commonly what that can be - or something cheap I can check/replace before going out and spending a ton? I know it's not the blend door because the icon takes a few minutes before it clicks on.
Brad S1
09-02-2008 11:00 PM
