-   General Range Rover Discussion - Archived (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/)
-   -   Cruise control line (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/cruise-control-line-29877/)
fire57dan Mar 21, 2010 10:59 PM
Cruise control line
Where does the vacuum hose that runs from the cruise control actuator plug into under the dash. My cruise control was not working so I followed the line and it was hanging under the dash. I looked around fairly well and could not see where it plugs in.
fire57dan Mar 28, 2010 12:12 AM
Has anyone replaced this line?
LRScott Mar 28, 2010 01:42 AM
I have not done this myself, You will need to remove the bottom panel to access the cruise control system. You might want to review the service manual before doing this, it will give you a better layout and or proceedure.
fire57dan Mar 28, 2010 11:59 PM
I removed that panel and didn't see anything for the line to plug into. The repair manual only shows the ecu and actuator in cruise control section. I will take another look though.
