-   General Range Rover Discussion - Archived (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/)
-   -   cruise control problems (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/cruise-control-problems-265/)
37chambers Feb 8, 2005 11:49 PM
I am having problems with my cruise control. The master switch turns on but the steering wheel controls have no effect. Any ideas??
Bait Feb 9, 2005 12:01 AM
RE: cruise control problems
Check the Vacuum hoses at the left rear of the engine compartment. Prone to splitting.
Bait
37chambers Feb 20, 2005 02:44 PM
The hoses look good. Not brittle and all of them have flex in them.
Bait Feb 20, 2005 11:41 PM
Need A little more info 37. You have A NAS vehicle ? Year ?
37chambers Feb 21, 2005 06:34 PM
I have a 1998 range hse.
Bait Feb 22, 2005 01:42 AM
OK, NAS Range, P38A
The vacuum pump is located at the lr of the engine compartment. Depress the throttle actuator whilst clamping off the line to the pump. Does it hold vacuum ?
river otterman Oct 18, 2016 10:52 AM
You can spray carb cleaner around vac hoses and it the engine changes idle you have a bad hose.
