driverside mirror
my side mirror does not dip no more what need how do you fix that
RE: driverside mirror
Have you recently changed your battery in the vehicle or remote?
no my passenger works
Ah ok. Have you tried resetting the tilt function? It may still be 'tilting' but the TILT position is the same as the normal position, or vice versa.
i did still no work
Alright..what about the mirror itself? Does it still have power control? It might have shorted out and needs to be rewired
WOW just for some reason i play with mirrow then i put it R and it works
THANKS |
Haha that's odd...at least it's fixed! Congratulations!
I'm having the same problem now. I let my wife drive the range for one week, now none of my mirrors are tilting. What is this reset tilt function? I might need to do that.
To 4.4Range:
What year is your Range Rover? If it is 2003-2005, then your mirror selector switch might be in the pass. side position. Switch it to the driver's side and then see if you have reverse dip. On these years, putting it to the pass. sideturns off the tilt function. |
| All times are GMT -5. The time now is 07:32 AM. |
