-   General Range Rover Discussion - Archived (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/)
-   -   Engine shuts off by itselfs (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/engine-shuts-off-itselfs-60668/)
NikkiJ Jul 24, 2013 04:28 PM
I have a 2006 range rover Hse. While driving slow (etc: trying to find a parking spot, pushing the gas after a red light, or traveling in a 25mph speed zone) my car decides to shut itself off. I restart it back up and drive on. I have also noticed that it tends to get really bad when I have my AC on. I live in FL where it is super hot so it is necessary to have my AC on. When this started I could tell it was sluggish in low speeds anyway but could not figure out what was wrong. My transmission light came on and shut itself off. I had it looked at only to be told they were soft default codes (letting me know something was not right) but since it went off they could not tell me what was wrong when they connected it to the scanner. They keep telling me to bring it back when the transmission light comes back on. Obviously this is becoming very dangerous especially considering I have a toddler that is in the car with me 90% percent of the time.
I have recently had a tune up and had to replace the fuel pump twice about three years ago. I really need to figure out what they deal is. I am always on the edge of my seat ready to put my car in park, restarted and slam on the gas to make sure it goes. Anyone know what it could be? Thanks in advance for any input you may have!
roverguy7 Jul 24, 2013 09:01 PM
I would start by cleaning the throttle body(a few threads with good instructions, same procedure as LR3 and RRS). If this takes care of the issue, go to a shop, and have an induction service preformed, and the PCV valve replaced.
Athana Apr 13, 2018 05:17 PM
Same issue.but..
Hi.Same issue..in winter works great but once AC kicks in when going slow or when stopped ..car shuts off.Throttle body cleaning? The mechanic said the Throttle body was sealed and cantc be cleaned?? Help!!
Athana Apr 13, 2018 05:21 PM
Same issue.but..
Our mechanic said Throttle body can't be cleaned as it is sealed..only replaced..help.
We have LR3SE 2006 V8
ArmyRover Apr 13, 2018 05:32 PM
He's wrong, you can clean it
Athana Apr 14, 2018 04:38 PM
QUOTEthanks..I called and they said electronic Throttle body can't be completely cleaned??
