LRScott |
08-19-2010 05:57 PM |
Looks a little rough around the edges. However, if you can get it for 900 or even 1200. I'd go for it. The parts on it alone are worth that. Plus if it drives great and seems to be alright, it will make a great vehicle. Classics are relentless if they get the TLC they need. I would check the transmission and transfer case. Put the transmission in drive put your foot on the brake and push the gas and see if it gets above 2500rpms. If it does not its a good transmission. BTW don't GUN IT, you'll blow it up even if it is good. Give it enough gas just to bring it to 2500 and see if it goes any higher. And only do it for a few seconds. I wouldn't be too concerned about the head gaskets. The old rover engines are almost bullet proof. $10 bucks says the reason the battery is draining is because they turned the radio off while the CD player was in the middle of a track. The computer tries to remember where you left off and uses a lot of power while doing so.
