Headlamp wiper troubleshooting
RE: Headlamp wiper troubleshooting
that motor is ties into the headlamp washer pump, if the pump goes bad, that wiper will not work. what you need to do is swap the connectors on the washer bottle pumps, the middle one is the headlamps. you can get to them under the hood down past the oil filter housing. swap that connector with another, and see if your headlamp wipers work, youll have no fluid comming out, but they should wipe. if so, you need a new pump. this is usually the cause when they fail down. when it stops in the middle of the stroke, its usually the wiper motor itself. to check, make sure you turn the key on and off a few times, and then hit the w/s washers after you turn on the headlights.
[/align]
bcolins
02-02-2014 09:40 PM
fireball168
11-11-2007 03:12 PM
mr mike
12-15-2006 10:55 PM
