headliner
Jenny Pearson (08-09-2016)
RE: headliner
Hi - I replaced the headliner in a swb classic about six years ago and now I have to change the one in my P38 '95 - I did the last one with an upholsterer whom worked for me. It is about a 6 hr round trip to do it (for one person, apart from lifting out the shell) - However it is not extreamly difficult. I did ask two trim shops in town and they were both around the $450 - $500 mark.
All the handles, trim and post pieces unclip and break fairly easily. The trim around the moonroof peels off, un-clip and disconnect the courtesy lights. The shell will drop right down and two people can walk it out of the tailgate. The moon roof is about an added 1 hr of work to pull apart and re-install.
Stripping off the foam is a bit tedious, and needs to be done properly so you don't end up with any bumps.
The fabric is cheap - the glueing is pretty easy, just need to keep clean.
Good Luck
Mike
P38 95'
Classic LWB 93'
Good Luck
Mike
P38 95'
Classic LWB 93'
RE: headliner
Couple things to note. You can't just spray down the headliner with adhesive once you rip it out and take the fabric off. The backing foam will just get coated with adhesive, and then once the foam breaks down again, your headliner will be sagging again. You need to use a cellulose stripper/remover and actually scrape all of the factory adhesive and backing off of the headboard. Then you have to wash the board very thoroughly to remove the stripper, or the glue won't stick. ONce thats done, you can apply the new adhesive and new headliner fabric.
Ceven if you still need to do this, I have a really good how to I can dig up for you on the process. It looks real easy, just time consuming. I'll be doing mine this summer, so if anyone's interested I'll do a pictoral how-to on this.
