help, knocking noise on engine,,,,
i have a 97 range rover 4.0 se , i only have it for 1 month and since last week everytime i use it i hear a knocking noise on the right side of the engine ,,
RE: help, knocking noise on engine,,,,
How many miles on the engine and when do you hear this knocking noise, hot, cold, all the time, under load give us more information?
Mike |
it has 103,xxx miles and i only hear it when the engine is already warmed up,, coz when i start the engine in the morning it sounds good but after i drove the car it sounds like a diesel engine,,
ORIGINAL: tobob1 it has 103,xxx miles and i only hear it when the engine is already warmed up,, coz when i start the engine in the morning it sounds good but after i drove the car it sounds like a diesel engine,, Mike |
i saw a post in this forum, that they just put a valvemedic treatment or do the engine flush and it mkes their engine quiet,, is it really a good idea or can it give more problem to the engine??
ORIGINAL: tobob1 i saw a post in this forum, that they just put a valvemedic treatment or do the engine flush and it mkes their engine quiet,, is it really a good idea or can it give more problem to the engine?? Mike |
The post you refered to was one where Mike and I cover most all possibilities of a "TICK". I took the entire top and bottom ends apart on my engine and cleaned it by hand. The valvemedic was temporary at best to at least thin the oil enough to suck through the plugged screen. I also had a different tick that only started after the engine warmed up. This ended up being the passenger side cat.
| All times are GMT -5. The time now is 04:44 AM. |
