HELP Locked out 2001 P38
Key is IN CAR doors locked and no 2nd key.
1. Brake glass and eat the cost 2. Call someone with a slim jim 3. Give up and just WALK AWAY Story: Car was super locking then unlocking after 20 min. Waited till I could open the door and bonnet. Removed the driver side (left) door control module so that it could not supper lock again, WRONG, Started the car to drive to dealer got out to close the bonnet, door closed since my big butt bumped into it getting around the car. Engine running, Bonnet open and the door locks tripped AS SOON as the door shut. No problem I left the door lock in the open position on the drivers door, BUT it must have slipped down and now can not get back in car. Pulled the fuse to shut off the engine then disconnected the battery. So car is off now and it is 31, #2 or #3 time |
There is away to get into it but for security reasons I cannot openly describe it on this forums.
If you PM me I will give you instructions, and I hope you can still open the hood. Otherwise you will need a battery some wire piercing fitting and a power probe. T/V |
Originally Posted by georgep
(Post 457355)
Ate one and used one, a SLIM JIM, door open now to fix the problem
Front Doors unlock but won't open
Originally Posted by tuercas viejas
(Post 457417)
If you PM me I will give you instructions, and I hope you can still open the hood. Otherwise you will need a battery some wire piercing fitting and a power probe. T/V Jesse |
Jesse you should post in the P38 section of this forum. This section is for modifications. Could your front doors be Superlocked? I’m assuming they aren’t just frozen shut.
Sorry, not for modifications, but you still should post under P38.
