L322 wet floor issue
Hi everyone!
I've just purchased my first range rover, - vogue 2003 diesel. There seems to be a wet patch on the far left hand passenger side floor. I don't think It's coming from the door or leaking from anywhere above as the ceiling is all dry etc. I did some research and discovered that it could be a sunroof or air conditioning drain could be clogged? Is this an easy fix and can I do it myself? Please keep in mind that I'm only 23 and don't have any experience with these cars so if anyone has any "advice for dummies" or a way to fix it I'd much appreciate it! Thank you.:confused: |
I would check the air conditioner drain first. There should be two, and they come out near the transmission. Look for two pointed rubber ends, that can be removed, cleaned and reinstalled into the rubber pipes. When i did mine about a half a gallon of water soaked my shirt sleeve. Hope this solves your water problem, It did mine. (my whole passenger side floorboard was saturated and even coming out the door)
