-   General Range Rover Discussion - Archived (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/)
-   -   Smoke from right Exhaust & low compression??? (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/smoke-right-exhaust-low-compression-13463/)
MacRR Apr 23, 2008 11:57 AM
I have a 4.4 2002, and I had it serviced a month or so ago (main dealer).
When it was picked up the car started to stutter and began to smoke from the right exhaust.
I took it back to the dealer and he said he would look at it. Anyway to cut a very long story short he hasn't fixed it and it still smokes.
I took the car to my local garage who is a friend of mine and he diagnosed the problem straight away.
He said it was a misfire from the front bank? Without messing with it I took it back to the dealer and explained the problem.
A few days later he said it was sorted. On my journey home it clearly wasn't.
I then returned it back to my friend who removed the spark plug and found oil inside. He reckons its coming from an internal leak and not valve cover? When cranking the engine there is a fine mist of oil spurting out the plug hole, he done a compression test and he said it was 125psi which he says is low.
I am getting well pi**ed of with it at the mo as I have just paid £2.5k for a new gearbox.
I hope this job isn't gonna cost me a fortune!!
I hope someone can help me!!
Thanks in Advance
Mac.[/align]
raid13 Apr 25, 2008 09:05 AM
RE: Smoke from right Exhaust & low compression???
did that just change out the spark plugs durring that service?
raid13 May 5, 2008 08:29 PM
so, what happened? any updates?
