Thank you all,
Disconnected and reconnected both driver and passenger yellow connectors. Also found that dealer service had left the driver side "unhitched" from its clip under the seat -- like some step-child. Thus, I suspect, every seat movement or "nudge" created the difficulties. 2000 RR Holland & Holland #34 - 96,000 |
All srs components have yellow connectors, or yellow sleeve or yellow conduit to id it as a srs system component. I have cleaned 100's of these connectors with contact cleaner.
I have the same SRS warning light problem with my '99 Disco...along with the Anti-Lock light.
Anyone know if there's a single point of failure, as in the brake lights/PARK lock pairing...? TIA! Michael |
Is it safe to be fiddling with these connectors with the battery connected? or do i have to disconnect it. Ive heard that disconnecting the battery can cause problems, and necessitate a trip to the dealership to reset the charging system in the computer. thoughts?
L |
I am on my 4th Rover, Classic, D1, P38 and now LR4, never had to reset after unhooking battery.
