-   General Range Rover Discussion - Archived (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/)
-   -   Transer case fluid (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/transer-case-fluid-52139/)
crznmyway Aug 22, 2012 04:12 PM
Transer case fluid
What kind of transfer case fluid do you use in a 2000 range rover hse and how many qt thanks cruz
Savannah Buzz Aug 22, 2012 05:27 PM
If dry, 5 pints, if refill, 4.2 pints. Both of these are US measure. If in the UK, also pints for all the lads helping out.
The RAVE shop manual says Dexron III ATF for the transfer box, this is different from Discos.
LRScott Aug 22, 2012 09:32 PM
This is correct. However, in the past some of our members' owners manuals state that there should be gear oil in the transfer case, and when they drained it to refill it, gear oil is what came out. A transfer case is not as complex as a transmission so it should do fine on gear oil or transmission fluid, but I would replace the fluid with what comes out and not mix them.
Savannah Buzz Aug 23, 2012 06:36 AM
Yes, but viscosity of gear oil is a lot "diff"erent than transmission oil. Not uncommom for people with older TC in a D1 to run 85W150. Perhaps a pro will rest his wrench for a moment and comment.
crznmyway Aug 24, 2012 08:30 AM
Didn't know for sure I had to go out and get a rebuild one so dont know what was in it so does it matter if its trans fluid or gear oil thanks cruz
Disco Mike Aug 24, 2012 08:50 AM
For the diffs, an 85/140 gear oil is the new HD standard.
As for the t/case, I believe Rover changed there recomondations over to gear oil also, if so, use the same 85/140 be it regular oil or synthetic is your choice but I always recommend synthetic for better wear protection.
threalassmikeg Aug 24, 2012 06:15 PM
All Land Rover Borg Warner Tboxes use Dexron3
crznmyway Aug 31, 2012 02:27 PM
Thanks Guys for all the help
