Water pump this easy??
Thought you would have to take off the shroud, pull the radiator and then do the above. OR can you just take off the shroud and go at it. The new pump I am getting has the FLANGE ON it so that was the big thing CORRECT? |
Mr. George, I mis-spoke on previous post. I was thinking of an older unit than yours. The RAVE certainly lists a lot of things to do, certainly on the 2002 (not sure if it is same as 2001). Good luck.
(Post 290328)
Yes it is that simple.
The '99 is a P-38, the DII and P-38 use the same engine so all work manuals will be the same for the engine. |
Originally Posted by Spike555
(Post 290445)
