windows or sunroof or mirrors not working
well i dont know guys it was like this when i got it (1995 p38 model)
however when i shift in to reverse mirrors move down towards the street and back when in drive i checked the driver door motor jumped it and it does work i have some what checked the switch pack best i could and it seems to be getting power to the board on the dash it says rear windows off? had not notice that before until today it normally says not set and pointers before i take it to the dealer to raped..:eek: |
Fuses?
Rear windows off means you have the rear windows switched off by pushing the switch to the disabled position (lower middle switch under the sunroof switch). If you've tried to re-engage them and the message won't go away, it is most likely a problem with the switch pack which is a fairly common problem.
fuses
Originally Posted by RROJ
(Post 186279)
Fuses?
switch pack
Originally Posted by LRScott
(Post 186280)
i dont know worth a check |
Check the connections first underneath to make sure it is all there and attached. I doubt the becm is causing this but I may be wrong.
Start with the switch pack since its the cheapest and easiest to repair/replace. I would only look into the BECM if there are other random electrical problems not related to the windows.
i'll start with the pack i really started doubting the becm because im not having no other electric problems really gas door button dont work and like i said before the cig lighter does not work ither but i dont think its related?
fixed it
it was the switch pack thanxs lrscott and everybody else who chimed in...:D
was it water damage to the board under the swiches?
