07 LR3 suspension won’t inflate then throws code
Im new to this forum. Thanks in advance for accepting me as well!!! I have an 07 LR3 SE. I’ve only had it for a couple months. But I’m now having air suspension issues. The system won’t inflate. I knew it had a leak on the front. So I replaced the two front air struts but only after it wouldn’t inflate and gave me the suspension fault code. And all control lights cut and switches disengage when fault is shown! Have anyone had this issue or can point me in the right direction for repair. I actually used a pig tail to run the pump from the fuse block but it still wouldn’t all the the system to inflate. Any help is greatly appreciated!!!
