Sponsored by: DashLynx
Urgent: Range Rover Gear changing noices?
Old 10-24-2006, 01:19 PM
AlexDeC's Avatar
Default Urgent: Range Rover Gear changing noices?
I want to buy a range rover 95 2.5 DSE from a local dealer, and I have to make the decision asap.
The main issue is,
When I drove the car, I found the change of gear 1 to 2 making noices (sounds like from gear box). However, if i first changed the gear 1 into neutral and then to gear 2, there were not noices any more. For changes of all other gears were quite clear.
My question is : is it in general a problem of gear box? or maybe it is a simple problem of clutch that I can relatively eaily handle?
Thank you very much for your kind reply.
Old 10-24-2006, 01:51 PM
Default RE: Urgent: Range Rover Gear changing noices?
Tranny noises must always be looked at seriously because of the potenetial cost of repair.
Mike
Old 10-24-2006, 04:32 PM
AlexDeC's Avatar
Hi Mike,
thank you very much for your quick reply.
I think I will not take the car then.
Best regards,
Alex
cocobelle01
01-25-2013 06:28 AM
kkrose
04-16-2012 06:58 PM
Greg
03-28-2011 11:09 AM
Greg
01-28-2011 09:24 AM
Torancis_LR
07-10-2009 11:27 PM
Quick Reply: Urgent: Range Rover Gear changing noices?
