2002 Land Rover Disco 2 - Hesitating
Replaced the fuel pump and the idle control sensor ....
No codes have come up now. Seems to be idling nicely but under load accelerating up a hill it still seems to hesitate and be cutting out a bit . When you stop on it , it will sometimes cut out then it ok. Doesnt seem to be running at full power. Not sure where to go from here with no codes. The only things I haven’t changed are the injectors, crank sensor and camshaft sensor . |
Dirty air filter? Possibly bad fuel?
You don't have any codes but disconnect the MAF sensor and drive your Disco. See if that changes anything. |
The air filter is clean and MAF sensor was just changed out to a new Beck Arnley insert ...
Almost like it’s starving for fuel but the pump was just changed out. |
