2015 LR4 - Check Engine Light
What the dealer is probably thinking is that your gas cap may not have been completely closed correctly, try taking it off and putting it back on. If the fault is not repeating itself over a certain amount of drive cycles the check engine light will reset itself. Mind you, when you spend the money you did on your new rover I would insist the dealer check the code and confirm their thoughts rather then make you wait it out.
