Abs help
I've never owned a Land Rover before and I purchased a 2000 Land Rover Discovery scammed office I put the new ABS sensor in and cannot get rid of Three Amigos lights what else am I doing wrong and anything else I should be checking for on the new Land Rover that I purchased with 173000
Originally Posted by Landspaz
(Post 640042)
limp mode? Sorry I’ve heard that called 3 amigos and I’ve been dealing w same crap and funny I never knew abs had anything to do w this but mine hasn’t went into limp mode anymore dude to new plugs/wires~ CPS~ XYZ Switch~ it’s insane I couldn’t pin point my exact problem but I hope you are able too. And I’m curious about this abs deal Bc mine threw the code for that but then ystrday did not 😣 I’m at a loss anymore lol |
Three Amigos is one of the more oft-discussed issues on this forum and others. Have you seen this write-up yet? ABS Mod - LAND ROVER CLUB V.I.
It's become the Rosetta Stone of fixing the Three Amigos around here. My Amigos were caused by the cold solder issue and bypassing the SVS circuit board (see Option B in that write-up) took care of it. Good luck. |
If you are even going to attempt to mess with ABS faults on a 99-04 LR Discovery you MUST have a scantool capable of reading LR fault codes specifically ABS fault codes. iCarsoft LRII is a great unit for example. Then you can get the proper ABS codes and faults. Without it you're just tossing parts at it and wasting time & $$$$.
Do a search for "Option B Mod". It will cure about 90% of the 99-04 LR Discovery ABS faults. Then you have the sensors themselves or the Shuttle Valve switches (I'd replace during Option B Mod). |
Originally Posted by Best4x4
(Post 640240)
Someone on this forum (I think) saw this unit hit Amazon for pretty cheap back when I was digging into my Amigos issue and I jumped on it. I use it on my wife's Mini and friends and family also borrow it from me from time to time. Really versatile. Cheers. |
Yeah that one works good from what I hear. I paid 100.00 for my iCarsoft LRII and since I also own an 06 LR3 the iCarsoft LRII has been extremely handy for the maintenance reset.
