ABS Pump
RE: ABS Pump
Mike thanks for the fast response.I have a 90’ Range Rover with 179K mi.
There is no pressure out of the pump only a trickle of fluid.
This all started when I started feeling vibration when braking. I put the truck on a lift to see what was going on. I notice that the front passenger side didn’t stop when the others stopped. So I then changed out the front rotors and calipers. (I assumed that the extra braking/heat on the driver side warped the rotor and that was the vibration I was feeling) bleeding the brakes is when I came across the issue with pump.
johnkbl
01-13-2009 08:54 PM
