-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   ABS, Traction Control, Hill Descent Trouble (https://landroverforums.com/forum/general-tech-help-8/abs-traction-control-hill-descent-trouble-1275/)
Sean 1313 Aug 17, 2005 12:24 PM
These lights continue to stay on. Sensors have been replaced, brakes, and master cylinder. Codes have been cleared by a Land Rover dealer which lasted about 3 days. The Discovery runs perfect and can't seem to find anything wrong. Any help would be greatly appreciated. By the way, 2001 Discovery Series II SE. Oklahoma, U.S.
Bait Aug 20, 2005 02:20 AM
RE: ABS, Traction Control, Hill Descent Trouble
Sean,
There are many issues that can cause the ABS light to stay on. You need to get it diagnosed by a competent repair facility.
duboff Aug 20, 2005 11:12 AM
The best i can do is have it checked again. There are to many points in the system that can cause the light.
use a good service that knows the vehicles. hope it helps. gotta love a rover. duboff.
LrTECH Aug 30, 2005 10:00 PM
You will most likely need an abs sensor overlay harness for whichever sensor is giving you trouble!!! Also if the SLABS ecu has not been replaced yet, that may need to be done as well.
