Another Three Amigo Problem
I know there are a ton of threads about the dreaded trio (ABS, hill, and traction-control lights). I have spent several hours reading through the threads and have not run across any sending the same OBDII code that I have. It is showing P 1950 on my reader and it will not clear or turn off the three lights. By the way we are talking about a 2002 Disco with 95,000 miles on it. The code accordint to the software was concerning Manf Cntrl Veh. Spd. Idle Speed Control Auxiliary Inputs, this is directly off of the screen. Anyone know what the code is referring to and is it something a person with moderate mechanical ability can change. Also does this have anything to do with the idiot lights being on? Thank you in advance for any words of wisdom on these problems. Our Rover dealer here in central Ohio seems to be really slow and expensive, two things I need to avoid.[8D]
Leon
Leon
RE: Another Three Amigo Problem
Thank you Mike for that tip. If I may pick your brain some more? Do you have any idea what is throwing the code P 1950 on the OBDII reader? The last time I worked on a car personally was my 79 Jeep Wrangler that was nowhere as sophisticated as todays vehicles. Also the Three Amigos flashed on while I was driving on the highway at about 70 mph, everything did seem fine I just heard the chime and looked down and there they were. Several days later the brakes started grinding, Being ignorant of what I was dealing with I had my local mechanic put new aftermarket pads on, no rotors. Could this be the warning light problem and if I replace the pads and rotors with Rover oem will the problem go away, including lights, or will I still need to find the proper device to turn off the lights. Thank you for any help you may have.
Leon
Leon
