black soot
okay i have black soot in both my tail pipes i just bought the 1999 4.0 range rover and drove it over a thousand miles home it was a great trip no problems it didnt use any oil and dosent smoke at all so were is the soot comin from the check engine light isnt on so im kinda lost o2 sensor maybe any help would be greatly appreciated oh the engine has 130 miles on it and i use 91 octane as did the owner before me
RE: black soot
i meant 130 thousand miles just to clarify
RE: black soot
How has your gas mileage been?
Black soot is usually and indication of the engine running rich. If your 02's have not been replaced yet, I would switch them out cause they are tired and will be causing you a loss in MPG and performance. Have you replaced your air filter lately, might want to check it. Are you still running the factory plug wires, how about your plugs, when were they changed last. Atlantic British usually has the best 02 prices and you must replace all 4 of them. |
RE: black soot
my mileage is aroud 17 mpg on highway havent checked it around town and the wires are brand sti spark transfer international not sure bout the o2 sensors just bought the truck and the airfilter is a paper type but is pretty clean i appreciate the suggestions discomike but if it were the o2 sensors wouldnt that throw up a warning light ?
RE: black soot
Is it possible that the previous driver simply used poor quality/discount gas, which contributed to the soot, and probably killed the O2s? I'm suggesting you do a Seafoam induction cleaning to get rid of the potential valve-destroying carbon build up in your engine if they used discount gas for 130k miles.
And O2's effectiveness decreases as the sensor dies. It's not a works one day, dead the next kind of deal. So you can have a very poorly functioning O2 sensor that does not trip a code. And I wouldn't worry about 17...I get 15 in my 4.6 :) Edit: Just saw the note about 91 oct. from the previous owner...It's possible he's honest and all...but I would still be skeptical [:-] |
RE: black soot
Buy 1 can of Seafoam gas additive, 2 feet of 3/16th vacuum hose and try to find one can of B&G's 44K additive and I will waqlk you through cleaning out your engine.
RE: black soot
alright got seafoam vacum hose and some lucas fuel treatment advance didnt have the B&G 44k but the lucas is some pretty good stuff i have used it before if you could tell me which vacuum line to put it in mike i would appreciate it
RE: black soot
ORIGINAL: armyproud okay i have black soot in both my tail pipes i just bought the 1999 4.0 range rover and drove it over a thousand miles home it was a great trip no problems it didnt use any oil and dosent smoke at all so were is the soot comin from the check engine light isnt on so im kinda lost o2 sensor maybe any help would be greatly appreciated oh the engine has 130 miles on it and i use 91 octane as did the owner before me It is in the nature of tailpipes to get sooty..especially in cold weather. It is also common for sellers of cars to clean tailpipes. Forget it until you have more evidence of something amiss. Enjoy the vehicle. James |
RE: black soot
ORIGINAL: armyproud alright got seafoam vacum hose and some lucas fuel treatment advance didnt have the B&G 44k but the lucas is some pretty good stuff i have used it before if you could tell me which vacuum line to put it in mike i would appreciate it 303-862-7680 Colorado any day before 8 pm |
RE: black soot
Get that carbon O-U-T
| All times are GMT -5. The time now is 07:28 AM. |
