Can old head gaskets damage block?
I'm replacing heads and head gaskets on my '99 DII and finally got the block cleaned up using brake cleaner and a wire brush. Underneath the crud there was a lot of dings to the block. I've attached photos of the two front corners. Is this normal? How perfect does the block need to be for the new gaskets to seal effectively? Can I proceed to put things back together or what do I need to do?
Extinct
09-10-2015 09:53 AM
RROJ
03-26-2011 02:37 PM
Frank4
05-18-2010 10:59 AM
