-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   coolant leaking from the rear of the motor (https://landroverforums.com/forum/general-tech-help-8/coolant-leaking-rear-motor-42408/)
jwolves Jul 19, 2011 12:20 AM
Hello I'm new to this forum i have a 1990 range rover county 3.9 L. my wife took my rover to work today because someone T boned her car over the weekend. she called me from work and tells me the rover was leaking coolant bad. so i put my truck on my tow truck and dropped it off at her job and picked up the rover. when i got home i put water in it started it up and no leaks so i left it run for awhile when it reached running temp it started leaking from the back of the motor. i thought it might have a busted heater hose so i took the hoses off and bypassed them. put water in it started it up no leaks. when it reached running temp it started to leak from the rear of the motor again. i tried to look down from the top of the motor but i can't see anything. so i looked at it from under the rover and it is leaking from the top of the motor. but i can't see where it's coming from. it can't be a freeze out plug because it would leak when i start it up or when i put water in it. so is there a hose or something that I'm missing at the back of the motor or do i have to take the top half of the motor apart
Savannah Buzz Jul 19, 2011 05:27 AM
Sounds like a gasket - could be head, but seems like you would have more issues with that. The valley pan gasket under the intake manifold might be the one. Since it is a "valley" stuff goes out the back. You would have to get to the valley pan gasket on the way to head gaskets anyway. Not sure if you have enough space to look in with a mirror, an inspection camera, or just poke a cam corder in the front (seems like a lot of room on my D1). Or some paper towels and see if they come out wet. Don't want to start such a project without a good look through the RAVE, exploded diagrams, etc.
jwolves Jul 19, 2011 09:07 AM
i have heard of rave where do i get it and yes i was thinking about the valley pan put like i said i can't see anything back there no matter what it looks like i'm going to have to remove a least the intake to look and see what it might be only thing is i can't find any part stores that carrie any parts for it here in Memphis tn except at the dealer and there prices are a bit much for my taste
jwolves Jul 19, 2011 04:23 PM
OK buzz i think you are right i moved some wiring and could see where the valley pan was all full of coolant i had to order the parts they will be here tomorrow i ordered the head gaskets and the intake manifold gasket 2 other gasket that go on the valley pan and the valve cover gasket not to bad of a price i called a friend that works at a car quest and he was able to find the gaskets for me and only cost me $89.00 i think that was a pretty good price don't you think i still want to know where to find that rave download if someone could let me know
jwolves Jul 19, 2011 04:30 PM
i also have another problem with it when I'm driving at night and turn on the high beam lights it will work fine for about 1 minute and then all the lights go out inside and out if i hit the low beam they will come back on i think it is the hi beam switch what do you guys think
