DISCO I - ABS - HELP
Hi,
exchanged two Front Wheel Speed Sensors yesterday. One was broken. Yellow dashboard 'Lock' icon still stays on.
Where is the ABS Main Control Unit Located? Where are the Rear Wheel Sensor Plugs hidden? Can you post a pic, or is it obviuos. Would it be possible that the main unit is broken caused by the worn wheel speed sensor? What to test?
Thanks,
mike
Thanks,
mike
RE: DISCO I - ABS - HELP
I haven't a Disco but you might look here to download a Rave Manual - Should provide some clues to help.
http://green-oval.com/joomla/index.p...&Itemid=29
Good luck.
Good luck.
ORIGINAL: Bill E
Good luck.
Good luck.
mike
johnkbl
01-13-2009 08:54 PM
