DiscoMike's 60K service list ?
on
Here you go, if you have any questions shout back.
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
12 Qts. of ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of synthetic DOT 4 Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant, also called DexCool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
12 Qts. of ATF
1 Serpentine belt
1 T/Stat
Bleed the brakes
kcferna
07-07-2009 08:33 AM
