Dll won't move
0722 - torque converter slipping
0103 - mass airflow sensor has a signal that is higher than speed range would expect
1884 - can't read with ordinary scanner, need dealer level unit to get the second part of the code (from tranny ECU)
I'd say check fluid level, and a fluid and filter change might be in your future. The lack of previous slipping is a good sign.
Ill check them ASAP and get back to you. Thanks a lot for the response
It's 2 AM here.... you need to open the attachment and see the picture from the RAVE of the connectors. Is this the year without a CDL lever, but has a spud on the transfer case for it? That you turn with a 10mm wrench? I guess if it somehow got to "N" then no forward or back.
I'm not to sure about the spud. Checked the fuses they look good. Ill get under and check the xyz switch in the morning and let you know. I've messed with it b4 took it off and checked it out it looked in good condition I've read about a hose above it
Hose*
