Fitting New Valley Pan Gasket
Hi, I'm finishing up a 04 DII head gasket job, fitting the new valley pan gasket. The rave manual says to put sealant on the cylinder head and block notches. I see old sealant on the block notches, but the cylinder head appears to have been a dry fit with the valley pan gasket. Am I making a wrong assumption that the manual means the head mating surface between head and lower intake plenum? What sealant do most folks use and where? advice appreciated. Thanks, Paul
