Freelander 99' - Back door won't open
Hi,
I cannot open the back door or window to our 99' freelander. Does anyone have any ideas as to why this is happening & how to fix it? Thanks |
RE: Freelander 99' - Back door won't open
The Window must open a little to allow clearance to open the door so I'd check fuses on the rear window first... If the fuses are OK then it'll likely be the motor or regulator
Cheers will check that out
| All times are GMT -5. The time now is 07:43 AM. |
