front propshaft repair on disco II
I'm in the process of replacing the u-joints on thefront driveshaft of my 2000 disco II.
The needle bearings inside the ball swivel jointhave fallen out. Anyone know where I can find a replacement for this bearing ?Any help would be greatly appreciated. |
RE: front propshaft repair on disco II
Go order a Percision 617 centering ball kit and you'll be set.
Thanks mike,
I put it back together yesterday. The kit worked great. For anyonedoingthe same repair Igot the percision 617 kit from napa Part# puj617, and the u-joints from AutoZone part# 1-0005. Also make sure you mark the shaft at all connection points before removal to make sure you maintain proper balance of the shaft. |
| All times are GMT -5. The time now is 05:29 AM. |
