-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   fuel pump tool (https://landroverforums.com/forum/general-tech-help-8/fuel-pump-tool-15393/)
pcrightler Aug 24, 2008 05:58 PM
fuel pump tool
Does anyone know where to get the LRT 19-009 tool to remove the ring holding in the fuel pump in a 97 disco???????????????????
bhorwhat Aug 25, 2008 01:44 PM
RE: fuel pump tool
You can get a new one here: http://landrover.spx.com/DisplayByGroup.aspx?id=8
but they're expensive.
This isn't a tool you're going to use very often - it may be cheaper to have the repair done by a shop.
roverguy7 Aug 25, 2008 07:52 PM
RE: fuel pump tool
just use a small prybar and a hammer, be careful not to miss, but tap the pry bar with the hammer to spin the ring, it has 'teeth' on top of it totap on... be sure to get it on straight when going back together
