gear shifting problem in my 98 discovery
Not having ever changed it also means filter will be clogged. IMHO you should locate an indy shop that does the BG 44 transmission fluid flush (or another high quality product). This can flush out a lot of the old gunk in the tranny that a regular change at this point would simply break loose (to clog filter and cause more problems). see BG Findashop - Search for an authorized BG service center near you!
Have the fluid and filter changed and then have a trans power flush done.
It is a old wive's tale to never change the fluid in a old transmission, would you never change the engine oil because you went over due on the last one?
it is your truck, have it changed, if they wont do it tell them you do not want a warranty, you just want the work done.
Bivwak2000
07-07-2008 01:09 PM
