hard starting 1996 disco
have a problem starting my 96 disco. was told it could be the map air sensor. replace with used one still having same problem. can i get some help pleaseeeeeeeeee!
RE: hard starting 1996 disco
does it just crank and crank or start and stumble whats up bro?
modyfyit it takes about 4 turns of the key to start this truck. after started it run as it should. talk to land rover mech. about this and was told that if i replaced my maf air flow sensor this would take care of problem ($600 a pop) do you think this is the problem. any ideas are welcome. tover [/quote |
